Use high speed counter Fx1s-10MR
JimHoang
Mar 2014
HCM city
Hi there!
I'm using mitsubishi plc for some project controling. I try to use high speed counter C251 to reading an encoder. I use two function move(MOV) and HSCS(interupt set bit) relate to value of C251 but It can't work even the counter was got value. I tried this code with Fx2N-32MR and it work well.
What happen with my FX1S plc:
Hi JimHoang,
Do you know what the counting speed is?
The FX1S has half counting speed as the FX2N.
Can you se C251 counting? If not, can you reduce speed?
You can also upload your program, so we can se.
/Dariusch
Thank you Dariush!
You can see the picture i shared that is the picture i take when monitored plc. The problem is why i cant move the value of C251 to D1 (value of C251 is 17 but D1 is 0). I'm sure i dont use D1 any time in my program.I'm sorry I can't upload my program now. I'm using smart phone now. I will upload soon.
Hi
I would go for the dmov and this should work,
Just remember it will take up two d registers.
D before an instruction in mitz stands for double I believe.
Donnchadh
Use high speed counter Fx1s-20MR
Hi there!
I'm using mitsubishi plc for some project controling. I try to use high speed counter C242 to reading an speed machine. I use two function move(DMOV) and HSCS(interupt set bit) relate to value of C242 but It can't work even the counter always was got value 0, and can't reset high speed counter C242
Hello Folks, Has anyone configured a Momentum high speed counter on Unity 13.1. We need the wiring diagram for Momentum High speed counter and...
82
i am bench testing a 1734 -VHSC24 Point I/O High Speed counter module, i cannot find any examples of wiring the outputs from the module. does...
1,398
Hello guys, I have created a program where I count the high speed inputs of a flowmeter and create pulses per second to check the flowrate. Next I...
1,794
Hello to all, I don't have to much experience in the PLC. I'm using the Studio 5000 v32.03 We are trying to measure the length of a product, in...
1,140
Does anyone know how to set the output window on-off values on the fly without having to inhibit the module? I could of sworn when I first started...
2,386
