Use Of Strng_i In Siemens Scl
Hello Aracioppi;
Post your programming attempt, it will be easier to attempt to help you if we see what you are doing.
Daniel Chartier
I'm not sure where to even look for an answer on this. I googled around a little but didn't see anything that helps. In my SCL code I have " IF...
3,083
A colleague is currently trying to utilise the IEC command "DI_STRNG" in an application at the moment. He needs to convert two different...
2,761
Can anybody see what's wrong with the following screen dump? I need to display an integer in a text field (a 20 character String). Originally I...
30
10,437
241
155
