Using a load cell on belt conveyor idler
Scott-bc
Oct 2008
Vancouver
As you all know there are suppliers who sell belt conveyor weight measuring systems that come with the electronic modules(integrators), load cell and weigh frame and speed sensor. I have an application where this would work for me but I don't need that much accuracy and budget is too high.
I was thinking of having one of the idlers mounted and suspended one a load cell with its output going to a load cell to 4-20ma converter. At the head pully shaft I would like to use and existing proximity sensor that would be used to calculate the RPM or speed based on the revolution of counts. From this I can also use a simple volumetric rate calculation for material going over the conveyor. Prior to using the scale the PLC would "zero" the scale read-out. I would also add to the calculations some way of calibrating the full range measurement value.
If I could get an weight accuracy of 5-10 lbs that would be fine. The head pulley speed is about 60-90 rpm, 2' wide belt and volume rate is about 1200lb/min of concrete.
I also forgot to add that the belt is driven by a hydraulic motor. The tail end of the pulley is fed by a hopper and it seems that the more full the hopper is the belt travels slower due to the weight of the concrete in the hopper
Thoughts on this?
I have done a basic set up where I use a transducer (With a 4-20mA output, approx £40) to measure the motor load current. This goes straight into the plc and gives a readout of 0 to 80 tonnes/hr.
I ran the belt empty and used this as the "Zero" and then ran the belt full and set it at maximum. It seems to scale reasonably linear.
My belt runs at a constant speed though, but you may find the flow/speed/load increases in a linear fashion.
I suggest you check out the single idler scale from Siemens, formerly Milltronics. I have installed many of those in mining applications. If you don't have the budget at least it will give you some ideas. You should measure the belt speed at a non-drive pulley (no slip), usually the tail pulley. The better you can align the belt the better the accuracy the weigh idler should be within a mm of the ones on either side.
Good Luck
Hello All, I have two bags of two different types of peanuts hanging on a load cell above two separate feeders. I am using Studio 5000 and would...
45
8,875
Hi guys, I am using LCSoft the calibrate load cell, the LCSoft send a specific value to PLC then i can use it and scale or calibrate in PLC Delta...
3,502
Dear all, I am upgrading the control system of an old asphalt plant and I am phasing the following issue. Two of its scales do not have 3 or 4...
4,759
Hi 2 all I had that project some time ago where i needed to calculate the conveyor speed. I have an incremental encoder 360ppm attached to the...
7,445
I've just created a small program and saved it. Then I clicked on the 'Download to device' icon and this dialogue box appeared. Do I need to...
20
1,458
