Using Bit output to signal input?
matlark
Jul 2011
KY
102
Is there a a way to signal an input from an output on the micrologix 1200? I currently have an external relay coil connected to a PLC output with the contacts running back to IN9 and IN10 on the plc. Can I do this within the software?
thanks
You can most definitely do it in logic, but, the way it's being done shows the plc proof positive that the output/relay is energized. I have alot of problems with the 1200 relay outputs getting "stuck" on. The indicator light is off on the plc, but power is still flowing through the output. I move the logic to another output and "problem solved".
fishenguy is correct- you CAN use the program status of an output to take the place of an input. but there is nothing like real world confirmation that your output is indeed energized and working.
Hi, I'm just looking for a simple way to make a button in excel (via VBA I presume) to toggle a bit in RSLogix 5000. I just got FactoyTalkLinx...
567
After watching The Universe is Hostile to Computers from Veritasium, I suddenly remembered a lost weekend years ago trying to reproduce the same...
4,422
What programming technique would use a bit position in a Timer's acc value? For example T4:0.ACC/1 using RSLogix500 in a SLC
2,895
Good Morning , I appreciate your help on a previous post.Your advice helped me understand more. My next question involves the same project...
3,577
Hello, First off, I would like to apologize for beginner question. I am looking to use a 'memory bit' to keep track of the status of an object...
1,301
