Using Flex IO
Prayder
Jun 2014
Arkansas
254
I know the 1794-AENT is a 24 vdc option for flex ethernet when adding a flex rack to controllogix. Is there a 120 vac option for the 1794 Ethernet standard?
We are upgrading a Micrologix 1000 to Flex IO and only have 120 vac in the cabinet and if possible I dont want to install a transformer for just one item needing 24 vdc.
Ah... so it takes in 120 vac and converts to 24 vdc for the ethernet flex? I didnt know that...
Thank you.
After replacing the 70 with the 525, the PLC can read from the drive and recognizes it as online, but no commands are being listened to. PLC is...
595
Folks, Putting together a system utilizing a Control Logix Gen 8 (5580) PLC w/ the L83e CPU. I'll be connecting to 8 different FLEX-IO drops...
4,124
Good Morning , I would like to start a Powerflex 525 with a N.O. Start Pushbutton , and when the N.O. Start Pushbutton is released I would...
1,740
Hi, I have a potentiometer connected to a siemens micromaster 440 to control a servo motor speed and they are not connected to any PLC. Now, I am...
4,095
Good Morning , I have a quick question about the Powerflex 525 embedded ethernet drive. I'm using a CompactLogix 1769-L18 and using Ethernet...
1,784
