Using plc to print labels
Oct 2010
Buffalo
I am relatively new to using plc and have fairly limited experience with them and with programming but have been reasonably successful thus far in acomplishing what I need to with them. However I have only used them for simple inputs and outputs (switches or sensors in, lights or alarms out) but never for any kind of data communication. I am currently looking into using a plc to tell a Zebra label printer when and what to print. The goal is to have a counting scale or other device indicate automaticly that it is time to print so the operator does not have to stop production and walk over to the pc to print or have to print multiple labels ahead of time. Im thinking I would like to simply have the plc control the software (anylabel) on the pc, just check that the program is running, open appropriate file, update the serial number and date and then tell it to print. Is this the best route? Can this be done? Has anyone done this or something similar?
We use Zebra printers hooked up to Mitsubishi PLC's, If you intend to use them I could give you a sample program to download and trial it. Regards Badger.
WE have just about every Mitzi PLC in existance here, around 100 in total the most common that are hooked up to Zebra printers is the FX2n
I have a project to automate four generator sets. The system will monitor and store the load demand of the factory. Once there's Power outage, the...
79
Hello, As part of our project, we are using an M241 controller. This controller interfaces with an industrial computer and a router via a switch...
144
I'm trying to write a data in Arduino using MODWR function block .I used the code I got from online for both PLC and Arduino. I made the wiring...
151
Dear all, I don't know why setup of password became challenging and weird. After setting up the password and try to upload the ladder from the plc...
185
Dear All, I need a sample PLC program to count the output pulse of a mass flow meter so that a specific amount of mass (for example 100gm)can be...
167
