Using RSLinx to read EDS files from Turck
bissotoe
Mar 2007
Texas
33
I have two computers using the same version of RSlinx. I also downloaded the EDS files from Turck to read the I/O. I registered the .eds files using the RSLinx tool. One machine can read the I/O devices, the other can't. One was set up about 2 years ago (the one that works OK), the other is being setup now. I am wonder if I am missing a file that allows RSLinx to read those Turck .eds files or if I am missing something. I checked the topics on both, they are the same. Any help?
An obvious question - you have registered the EDS files on both computers, haven't you ?
Hello all. My rslinx freezes for several minutes each time a USB device is browsed. I thought I was freezing indefinitely, but disabling...
608
Is there something like Help About that will tell you that each Rockwell application is licensed? The Activation Manager just shows every...
2,740
Question – I am running the RSLinx Classic Gateway OPC server (4.00.01 CPR 9 SR 10.0) on my laptop, with a directly connected Ethernet/IP...
2,625
I am building a new galaxy for a customer and I am trying to test things as I go. All my Ethernet PLCs are OK, but I have a test PLC5 in my...
2,159
='\\OMK-MAINT-VM01\NDDE$'|[HT_Data_Collection]REAL_Array1[4],L1,C1 Where "OMK-MAINT-VM01 in a VM on the company network [HT_Data_Collection] is...
1,049
