using rto in connected components
Mueller34
Jan 2022
Wisconsin
56
Hello,
I am new to playing around in connected components and using RTOs in general. My question is does the RTO instruction in ccw have a timer timing bit like the TONs and TOFs in rslogix? I'm guessing this is just the input bit?
Thanks,
Eli
Yes, well, [XIC input_bit] ANDed (in series with) [XIO rto.DN]
Or is that rto.Q, I forget?
rto.q would be the done bit. I just wasn't sure if ccw had a TT bit like in rslogix 500. the TON has the REDGE bit. Which I did find that the rto has the .IREDGE bit which is pretty much what i was looking for
I believe you have to make your own form of a TT bit in CCW.
+1
Cf. this link.
TL;DR
.IREDGE in CCW is the same as .EN in RSLogix 500.
There is no equivalent in CCW for .TT* in RSLogix 500.
* .TT is "Timer is Timing;" see this link and image below.
See also CCW Trend below demonstrating that .IREDGE is not analogous to .TT, because .IREDGE does become 0, like .TT does, when timer completes.
I am using an RTO to log the amount of time a button has been pushed. I was wondering when I add it to the rung how do I set the preset? It wont...
1,894
Hello, fellow PLC enthusiasts, I’m a newbie in PLC and am currently on a project that involves connecting an Omron CP1E (CP1W-CIF11) PLC to an...
74
Hi, I wrote a sequence loop using EQU and MOV instructions and would like to validate that i'm doing this properly. i attached a picture of the...
623
Hi I'm very new to PLC programming and I'm trying to find out if this library (Tc2_NcFifoAxes) is necessary for our task In our case we need to...
65
I have a project to automate four generator sets. The system will monitor and store the load demand of the factory. Once there's Power outage, the...
98
