I have a problem comming up with the best solution for after switching from manual mode to auto to balance valve posistion.
1. Valves have posistion resistors monitored with converters, 0-10v into PLC
2. Manual mode two valves opened and closed thru switches on
panel.
3. When returning to Auto mode combined % open added together for a % value needs to be balanced between the two valves.
example-
% open among both valves added together is 40%
valve 1 = 25%
valve 2 = 15%
need both to balance at 20% each maintaining the 40% total.
Using RSLOGIX 5000
panel.
example-
valve 1 = 25%
valve 2 = 15%
Using RSLOGIX 5000
