vb and string variable in db
MAHER
Jul 2007
CAIRO
82
Hi All,
i am trying to read some variables from Siemens plc (DB ) but i am trying to read these by using Visual basic
but the variables which i need are ( string type ) and ( date and time type )
so please is it possible or not and how can i do it by visual basic .
thanks in advance
maher
Libnodave ?
You are using Libnodave for de communication ?
VB.net ?
Regards
Combo
Hi All,
thanks in advance
maher
thanks all for fast replying.
now i am using s7prosim to check the code withplcsim but in real life i will uselibnodave lib because i dont know any thing else so if if it is possible by libnodave please guide me and if by active x ok please let me know how can i do it.
because i will try to use it inside the Excell sheet. to get data from DB through TCP/IP and write it down directly to excell aheet.
i am so sorry for conflicting you but i am really new in using macro and VB.
thanks for your support.
maher
I am using Kepware to connect to a Keyence KV PLC. I am trying to read a string variable DM20021. Kepware error" string is not valid for DM20021"...
598
Long story short, I am creating a display to display an array of Strings from PLC [topic]VarStrA_RPHD.Desc[VarStrB] totally 100 strings...
1,417
Hi, In Twincat3 x64 is it possible to get value of variable of which name is read from a string variable? VAR VAL1 :REAL:=555...
1,225
Hi! i try to use string as variable name in a forloop my problem is tahat my if insturktion not allow strings as variable name. my declaration...
2,386
Good day. The problem is the following, I am using the Machine shop parker program to program an HMI that communicates with a logix5573 PLC. I can...
1,270
