VB6 Winsock to Omron Ethernet connection
Karan01
Nov 2006
CANADA
I would like to share data between an Omron PLC (CJ1M) and VB6 by using a winsock VB (6.0) through ethernet. Does any one have sample code i could look at before i try and re-invent the wheel? I have the port opening and connecting OK. i believe this may be my command formatting. Ideally i would like to use the FINS UDP port (9600) and the associated commands, rather than socket services. Any help appreciated.
Does anyone have vb6 winsock code to connect with omron (cj1m PLC)through FINS ethernet.Any help appreciated
2,363
Hello, I'm trying to solve a problem. The visualisation is done by VB6. How can i figure out wich databit in S7 is linked to wich variable in VB...
1,543
im doing some coding in vb6 and i have an error in this line : Dim myOPCServer As New RSiOPCAuto.OPCServer it gives me this error when compling...
2,304
Good day all. I have a SLC500 that is controlling an air flow rig. The HMI is a PC using a home-made program using VB6. I have no experience with...
4,485
does anybody have an example of how to connect to a 90-30 ge fenuc plc with the SNP-X protcol through visual basic? i have seen something on this...
1,889
