Very Low Cost Modbus PLC
Archie
May 2002
Orangeburg, SC
1,944
I'm investigating the possibility of developing a Modbus driver for the Advanced HMI project, but I do not have any hardware that supports Modbus.
What is the lowest cost PLC I can get that supports both Modbus over RS232 and Modbus/TCP over Ethernet?
I looked at the Automation Direct CLICK, but it does not support Ethernet.
Archie,
There are many Modbus simulators available for PC's. They can be masters or slaves. I think this is the way to go as you will get much more information than using a controller. Obviously, you will want to test on real hardware eventually but to start out a simulator might be easier. Something like Ocean Controls Modbus View comes to mind.
I was just telling someone today that it would be great to have a Modbus/TCP driver for your Advanced HMI system. I have some I/O blocks for using for demo's and they are Modbus/TCP. It would be great to setup an Advanced HMI screen or two for displaying them.
Please keep us posted.
Thanks for the suggestions. I'm not sure why I didn't think of a simulator, but I did find one here:
http://sites.google.com/site/plcsimulator/Home
It also has a simulator for DF1 and I tested it with the Advanced HMI.
This simulator will get me started on the Modbus driver.
I'll have to check the Beckhoff hardware to see if they have a controller that supports Modbus over both RS232 and Ethernet.
Horner XLe, XLt and Horner XL6 support Modbus.
Add-ON etherent module will get you Modbus TCP.
Prices vary but you cna buy the units that come with no build in I/O which are cheaper.
Archie,
You could borrow a Red Lion HMI and set it up as all three options, Modbus RS-232, Modbus RTU via RS-485, and a slave on ModbusTCP. Find out who sells them in your area and see if you can borrow one. Most of guys on the street will have a few to loan customers to try out.
Thanks,
Joe_WaZoo
Thanks for the additional recommendations.
I've been using one of the simulators and now have a rough prototype driver working with Advanced HMI. I should be able to post a Beta test version in about a week after I do some clean up on it.
Hi guys, May I ask if you know of any device with as few as 3 inputs and capable of ethernet connectivity? I have a project to monitor a number...
20
6,896
Hi. Importing a 2014 aapck in 2023: no problem using it, adding windows, works very well, no problem whatsoever. Creating a new project: as...
765
It takes a minute or two just to open, I think this is from the license checks. After it is open it takes like 5-10 minutes to upload a 2.5MB...
1,215
Kindly, we are trying to go online on an S7-300 plc, with profibus communication, using a CP5711 adapter. But when we open the Ladder and press...
790
Hi folks, I have a hydraulically driven rake in a clarifier that rotates at about .18 rpm. When there is a process upset, the bed of the...
3,734
