VFD as DC power supply
goghie
Jan 2008
Belgrade
800
I need small power supply that has very small ripple and 250VDC for my workshop. I came to idea to use DC bus from VFD that has 3x230VAC output as it seems cheapest solution. Any thoughts or suggestions?
Instead of a vfd, why not use a dc drive? Ive used abb dcs drives as variable power supplies to feed eddy current dynos before
@BryanG
I know the value of DC bus, but it is easy to set-up to 250VDC.
@g.mccormick
I intended to use VFD as I have one good Mitsubishi on stock :)
I have to admit that the last time I put much effort in to studying VFD circuits was in college, I think Eddison and Westinghouse were still arguing about whether AC or DC was better. If your VFD has a way to control the DC Bus voltage then you have your solution. The ABB drives that I commonly use only have DC Bus Voltage as an output value.
@Australlan
I will control it with High Power Wirewound Precision Rheostat, as it is for testing equipment that has very small load but it needs to have the output of supply as smooth as possible.
Hello, I am working to design a simple system where I would like to power the VFD directly off of a DC power supply rather than 3PH power. The...
31
7,963
I have an issue with Power Flex 525 during running processing, the VFD stopped suddenly while the PLC and VFD connection ok, VFD does not have any...
128
We have a devicenet consisting of 15 PF755 drives in a centerline MCC, and on a separate trunk cable coming off the scanner, a single PF525 in a...
339
Hi, I have a VFD from wich I cannot read the power output. However I can read the current and voltage. Am I correct to say that this formula will...
3,889
A little background at my complex we run power flex 755 VFD's 480V most of them are 361 Amp. They are etherneted to a controller the VFD has a...
5,447
