VFD Parameters Effects
eyad267
Jun 2009
amman
62
Is it possible to find a tutorial or an ebook about the effects of changing the parameters for an AC motor inverter? (other than the manuals)
I have got the manuals with the inverter but i am new at this and i need to study the parameters first because i am afraid of the bad effects that could result for a rapid change in some parameters or for exceeding the values...
I am using LG Inverters
Thanks in Advance
Hi there
I would like to know whats the problem with manuals??
E-book I think u wont find as parameters of inverters of different makes are different. Only the manual of that particular inverter can teach u the effects and side effects !!
The 3-wire system for example? what are the bases to choose the maximum frequency? maximum voltage? timings? Reset systems? the advance things like making a password?
I think I see the problem. What you need is a good introductory primer on motors and VFDs.
I recommend as a starter:
Electric Motor Drive Installation and Troubleshooting by Glen A. Mazur and William J. Weindorf
ISBN 0 8269 1250 8
It is a bit pricy like all good textbooks but you may be able to check out from your library.
Dan Bentler
Looking for some assistance. I am very familiar with Yaskawa VFDs, but not so much with AB VFDs. I am working on some hardwired AB PowerFlex 700...
149
Hello hope you are doing well! I wan to read the next parameters of a VFD 525: 1. Output Current 2. Average Power 3. Energy Saved to display...
662
Hi, I'm currently working on a machine equipped with Rockwell PowerFlex VFDs. I have one PowerFlex 753 (rev 6 or so) and two small PowerFlex 4M...
1,995
Hi, I have several Yaskawa V1000 VFDs connected via Serial Modbus to Opto22 serial modules. Everything is sort of working. I was able to set...
1,961
Hello, I have a AB Powerflex 700 VFD drive that I have connected to our network via a CAT5 cable to a switch. I would like to read various...
2,352
