vibrating feeder with VFD
Charbel
Jan 2012
Beirut
307
Dear,
i was reading about vibrating feeders with VFD's with embedded controller. I understood that VFD will be needed to make constant speed rate at various load conditions and will make the feeder start softly (soft start). how this is done? is control done automatically?
Thank you for your feedback,
charbel
Normally you have a flow rate setpoint. You will control the speed of the vfd to try and get to that setpoint (normally with a plc or some stand-alone controller)
Thank you dear,
Do I need to connect the standalone controller to a field instrument (for measuring speed or anything else) or is this done automatically by the standalone controller based on flowrate setpoint.
For higher accuracy you can get the speed feedback but most of the cases ive done vibrating feeders this wasnt neccesary. You will use the flow rate (scales,weight) as your process variable and just send a speed output to the drive according to the flow rate.
If your vfd has the option of pid controller built in you wont need a standalone controller or plc
Hi Gents, Is it advisable for a tuning fork level switch to be installed near a vibrator on a vessel.
2,393
I'm just starting to learn about industrial automation processes, I want to know how a weight feeder unit works which consists of a load cell and...
1,096
Been awhile since being on here. I’m looking for supplies of small Stainless-Steel auger/feed screws. Probably about 1.5 – 2” in diameter with...
1,642
hello, i am trying to design a conveyor belt feeder , to output mass flow rate of my bulk material (ore) , we have a belt conveyor and we should...
3,940
I have been going over my notes from a UL class from years ago and was trying to see what effect on SCCR a power distribution block would have in...
3,441
