OT – Home feeder project
Bob O
May 2003
1,873
Been awhile since being on here.
I’m looking for supplies of small Stainless-Steel auger/feed screws. Probably about 1.5 – 2” in diameter with pitch, shaft diameter and length not critical.
Basically, if there is a supplier that may have stock augers, I’m flexible.
Thanks,
Bob O
What size food chunks or pellets are you feeding? Ground chicken feed, rabbit pellets, grain for cow/horse/pig, large size dog food, Monkey Chow (which is BIG pieces)
For industrial I have only dealt with powders, but Direct Industry has a variety of systems, they might sell just augers.
For powders my favorite is the Liad PowderSave
Cool Factor: Just searching for the link I found a magazine article about the first system I built using their dispenser on
Large size dog food is about the size.
Any farm tractor suppliers in your area?
They usually have trailer mounted augers for farmers to move grains for feed and crops
EDIT{ Also there are smaller 'poultry feeders' that are shorter, but might not handle chinks like dog food, as they are designed for ground feed
The auger diameter I'm looking for is in the area of 1.5-2"
It's a home feeder project.
If this is for large dog food sized chunks a 2" diameter auger might not be big enough, especially if it has a center rod and not just an unsupported spiral.
Flex-Auger has this spec sheet showing the allowed pellet diameter, their 2" (56mm actually) only handles 6mm feed and it doesn't have a center rod.
Hi Everyone, I have a project involving a Beckhoff IPC with Twincat and a Yaskawa servo motor and drive. I'm trying to use the MC_HOME function...
504
I set up a Mitisubishi test system on the bench. Q03UDSPU Q173DCPU MR-J3-40B HF-KP43 HMI is a LS XP50 TTA/KP43 I am trying to use a signed...
396
I'm looking for some starter kits but there aren't so many on the market, so I'm thinking about buying individual components for my needs. I just...
2,466
We have a 5 Ton Rheem A/C unit at home We only run it in the Summertime, and sometimes in the Fall. It does have a habit of blowing fuses at...
18
2,484
Hi All, At work we primarily use Rockwell products and they are pretty good to work with and rock solid for industrial environments. A little...
1,065
