Vibration Monitoring
cwildgrube
Mar 2019
Wisconsin
Need help with monitoring a set of bearings on the roof top dust collector fan unit. Have access to CTC Pro Lp300 sensors, AB-850 w/analog input module or a 1400 with analog input. Need help with logic monitoring thresholds of each bearing if its possible. Has anyone accomplished this on the cheap like I'm tasked with doing? We have handheld monitors but I'm not wanting to send my technician up on the roof all the time to gather 20 minutes of data every week so I'd like to monitor the 4-20mA with a plc and alarm off when we hit a predetermined threshold. Is it possible with this hardware, and if it is, what is the best way to do it? I thought about scaling the analog to a 0-100 (percent), setting a threshold of say 60 (whatever our threshold is from baseline) and alarming off if it gets above that mark for "x" amount of time.
Would this work and is this the best way to write the logic?
Chris
If you’re open to other sensors, we like Banner QM42VT2 sensors. They have two axis of vibration and temperature in Modbus data. They’re around $200 each. I have read them with ProSoft in CompactLogix, MicroLogix 1100, Click, and DirectLogic 06. This year we will put some on our roof with Micro 820. We will run ethernet and power, probably DC, to each controller and MSG to ControlLogix.
Banner markets these primarily for wireless, but we don’t want to maintain batteries. We use Turck fieldbus blocks and cables with these.
The sensor you have should work fine, and how you propose to do the programming will also work well. The one thing I would add to the program would be some tracking logic to show decay of the bearing over time. That would help you work out a good PM schedule for the machine.
IMHO there is no such thing as the "best" way to program anything, but KISS is always a good guideline to follow.
Bubba
Good Morning , I know Banner has some nice wireless monitoring systems , does anyone know of any other systems that monitor temperature ...
3,518
I am commissioning VMS installed at NTPC and we are using XM120 as dynamic measurement module and XM441 as relay extension module. The problem I...
2,067
Recently I am facing an issue with the BFP Bently Nevada 3500 VMS cabinet I/O card burn issue. Below is the system description : 1)...
2,785
The existing vibration monitoring card is faulty and will be replaced with another one. Do I need to download any configuration or just let it...
1,924
Hi, I am Looking for a System Configuration drw for a Vibration Monitoring System. This is For 3 VT Pumps each of 1750KW and Pumping raw water...
3,404
