Vijeo Citec multi clusters
Yes as far as I know but have never done it. Contact support to be sure - if it is under a maintenance contract (it should be) it will cost you nothing to ask on the global support site - they are very good.
I thought that the idea behind clusters was more along the lines of trying to minimise the connections to the PLC (usually the communications bandwidth limitation is the IO server to the PLC)
If you have a Tag limit issue then how about one Common cluster for the common IO and separate clusters for each other system
We could help more with more information
Hello BobB, Thank you,
I have 24 M340 PLC, which communicate via radio and GPRS DNP3, with another M340 connected to the Citect supervision. The idea was to make a cluster for each of the 24 M340. I think with this solution can help me in terms of management alarms and statistics. What do you think?
Perhaps - I have not investigated that path. Equipment (machines) may be more useful to you I think.
Clusters can cause some confusion with operators with some operators I have heard but have not gone up that part at present.
Hello BobB.
What is the most correct way to put the value of the date and time of the PC supervision Citect, in a variable 40000 Modbus? From what I saw is possible via VBA ("Now" function), but I did not realize how introduce the value in type 40000 variable.
Can you please give me help?šŸ™ƒ
No idea I am afraid - have never written Modbus values from Citect. Best check with support or read documentation. There is also a users group and a Q&A database.
i m having vijeo citec v7.2 and its logging data thruogh sql perfactly. i add 4 table recently and its logging perfactly. but now i want to add...
3,062
Good Day all. I am currently busy with a schneider HMI design in vijeo designer and i want to know how you can animate an image to move on the x...
188
Hello, I have been tasked with adding some analog signals for display and alarm setup in some old Schneider Electric HMIGTO HMI-panels. I have...
185
My system are taking data from RHT sensors, around 45 points. Now I want to make a function in which, if the data is #BAD or 0 in values for all...
483
I have DI module ICPCon M7024UD connect to my pc using COM3 MODBUS RTU and also RHT sensors are using MODBUS TCPIP.. The problem is, it cannot...
1,673
