VIPA 253 PLC upload
technolog
May 2015
Ohio
320
I have a Vipa 253-1NE00 PLC from which I need to get an upload. It seems to be rebadged Siemens parts. Do I use Step7 or something else? Which cable do I need?
Thanks in advance.
The Vipa software I have wasn't free, but the Vipa PLC's can be programmed with Step7.
Use the standard Siemens USB PC adapter for MPI or the 5512 card if your laptop has PCMCIA.
There are some internal things the Vipa software does with Vipa PLCs that Step 7 won't but for the basic programming and monitoring Step 7 works.
As far as I can see, this PLC only has an ethernet port. I've been trying to figure out the IP address, with no luck so far.
I'm assuming that, because the part number includes 253 - i.e. in the 200 range, I'll need to use Step 7 Micro/Win. I've just had to use Micro/Win to get an upload from a Siemens S7-200 PLC
Following SigmaDelta's post it seems you are looking at a remote rack.
The Vipa is/was a clone of a Step 7 PLC and uses regular Step 7 software.
I have seen applications where the Vipa CPU was on the side of the control panel away from all the IO racks, so look around the panel for where all the Ethernet cables go and my guess is one goes to the CPU, which will have a MPI port on it for programming.
Dear sir, I am using SIMATIC 300, CPU 315-2DP , (6ES7 315-2AF03-0AB0) VIPA 603-1CC21 A1.0 RAM 32KB, Firmware=V4.0.8 The problem Im using MPI...
167
Got a VIPA 315-2AG23 that i try to go online with but can't seem to make it work through a network. I can go online if i'm plugged directly in the...
272
Hi guys, I have VIPA MCC 953-1LK00 1 MB, but it is blank. Does anybody have image for this card? Thx in advance.
809
Hello Friends I need to monitor a PLC Vipa. Which software and cable do i need? The upload will have the comments? Thanks in advance.
1,533
Does anyone have the pinout for a vipa Greencable? I am trying to connect to a unit using the multitude of Siemens MPI adapters I have tried USB...
1,131
