VIPA CPU-314 and Magelis XBTG 5335
viper1333
Nov 2009
Gdynia
Hi Everyone,
I'm trying to make visual for program that works on VIPA System 300S SPEED7 - CPU SC 314-6CG03 and Panel Magelis XBTG 5335. And I don't know how to take for it. Both of them has got IP adresses. Magelis is programming from Vijeo Designer and there is driver for choose TCPIP for siemens300/400. But it doesn't work and I don't know what I do wrong. I was trying crossed and normal LAN cable, router, switch and directly connect.
Maybe some of U work with this combination of PLC - HMI.
Thanks for any help.
Hello I`m working with VIPA systems. I think that problem can be in the protocol you are using, because VIPA TCP/IP is not the same as Siemens TCP/IP. VIPAs Ethernet port is passive port using MPI protocol over TCP/IP interface.
Unfortunatelly i have no experience with your Panel Magelis and its software...
Hello,
I had message from Schneider's people and they write something about protocols too but not in such details as U.
Thanks for answer.
I`m the only one responsible for VIPA in Czech republic ... If you want I can send you a contact to the Poland responsible ...
I have contact with them. SDS-Automatica are oficial sellers for VIPA in Poland. BUt U helped me more.
Thanks one more time.
Hi Experts! I need your help please! This is my case: I'm setting a VIPA PLC (CPU 314SC). it has two ports and its defatults protocol are MPI and...
2,032
Dear sir, I am using SIMATIC 300, CPU 315-2DP , (6ES7 315-2AF03-0AB0) VIPA 603-1CC21 A1.0 RAM 32KB, Firmware=V4.0.8 The problem Im using MPI...
176
Hello Friends I need to monitor a PLC Vipa. Which software and cable do i need? The upload will have the comments? Thanks in advance.
1,543
Hello all. I have trouble getting online with TIA portal V15.1 with a VIPA CPU(VIPA 315-4PN12). If I try to connect I get an error message that I...
3,376
hii friends, we do not have a source program of it. Siemens manager 5.5 can not upload its program fully because one db is big enough to stop...
2,038
