Vipa PLC wireless communication
tbouheiri
Oct 2018
Abu Dhabi
Hello Gentlemen,
I've just registered and this will be my first post :). I am still a beginner in PLCs especially in communication configurations.
I finished programming my PLC which is Vipa 214-2BE03 using winplc7, and I am willing now to set up a wireless communication between 2 plcs with same type, but still I am wondering how I can achieve it.
From hardware side I know that I need wifi ethernet switches or radio frequency routers. And from Program side I will be using the GET and PUT instructions , SFC67 & SFC68, however I am not so sure how to make hardware configuration for this whole setup using winplc7.
Thanks in advance guys and I would appreciate any help.
I’ve never heard of Vipa before so don’t know anything about programming them however typically wireless communications (when utilizing the hardwired communications port) is no different than hardwired other than sometimes you need to take the lag time into consideration. I would start by making the two devices talk to each other without the radios and then put the radios in and see what happens.
I have a Vipa 253-1NE00 PLC from which I need to get an upload. It seems to be rebadged Siemens parts. Do I use Step7 or something else? Which...
2,692
Happy Holidays! I have Siemens Simatic Step 7 v5.5 and I'm wondering if you can use it to program a VIPA PLC? or do you have to use the WinPLC7...
3,948
Hi guys, I have a question about using module MVI56E-SIE to CLX frame for communication with VIPA 300S Speed7. I know that is this module...
2,705
I am facing communication error in our system, VIPA system 200 PLC is connected to Pro-face ST402 HMI unit. I am continuously getting an error...
2,028
All, I am working on an PLC controlled vessel, but the PLC program has been protected by code by the maker of the program Is there any suggestion...
1,462
