Visibility of objects in PB32
dlweber
Oct 2014
PA/OH
405
I am trying to make some buttons disappear on a PV unless a certain bit is set (I am used this being referred to as visibility.)
I have never used PanelBuilder32 before, my first project here is to convert away from PV. For unrelated reasons we are not able to change this panel at this time, and of course the COO wants this done immediately.
The objects I am trying to make disappear is five buttons (up/down selects and an enter) and a change screen button.
The problem is I cannot find where to do this at, in the object properties tab there is no option for it and the help function does not work on this version of windows. I have looked through many drop downs and hovered over the icons with no luck.
If it script that needs to be wrote can someone give me a sample of the code?
Or is this just not possible?
PanelBuilder32 03.83.01 B7
PV600 RiO
SLC5/04
Hi, I wanted to ask is there a way to have a visibility expression use the IP address of the HMI (Dynics, not PV) to show certain elements? The...
208
Hello, hope yall are doing well. I have a HMI program where I need to add a "GoToDisplay" button, so when this button is pressed, it goes to a...
894
More help again please... See the picture. I want to make the rectangle visible when Mr_Zr_ToggleSwitch is 1, and make it invisible when 0...
2,484
I inherited responsibility for a large FTView SE ver11 application. This application has close to 500 displays. Visibility has been applied to...
992
I have 3 groups of users under security settings. i want a button to be visible when group1 or group3 logged in, and invisible when group2 is...
1,273
