Vision and servo control
rokon
Jul 2008
Auckland
Hi, I am final year university student undertaking a project for an industrial company.
The requirement for my project is to identify a feature on a part, identify the orientation (angle) of the part compared to the desired orientation and use a servo to rotate the part to the desired orientation.
It has been concluded that vision is most appropriate for this project. The vision camera will be Cognex (insight) or an Omron system.
What I would like to know is what components are required to build such a set up. I do not have any experience in such a field but I would like to learn.
My guess is that I would require:
- Vision camera and software
- Servo (or stepper motor)
- Servo driver/controller
- PLC
Please advise me how can I connect up the hardware and what other extra components are required, cabling etc?. Is there any material on the Internet I can read about this?
At the moment I do not have any specific information on the make of PLC and SERVO.
Thanks for your time
rokon said:
Anyone? Do you want me to clarify anything?
A common complaint is people not supplying enough information for us to use to help you.
The second complaint is in a nutshell students asking us to do their homework. However you did say
WHAT CAN I READ??
Some questions you can answer and you should have these right on the top of your head
Describe the "visual aspects" of the part ie color contrasting colors,
Describe part -- material, dimensions, topographical (?) features and dimensions,
Describe speed requirements ie parts per hour etc etc
Describe inspection tolerances what are you going to discriminate between good part and bad part??
That otta get em scratchin their heads.
Dan Bentler
You want to use a camera that can write data to a PLC or motion controller using Ethernet. The Cognex can use Ethernet/IP. This way information will just magically appear in the PLC or motion controller.
- PLC
You probably don't need the PLC if you get the right motion controller. The Cognex can download coordinates, angles and identification directly to the motion controller.
Plenty but your question is very vague.
Like I said the PLC probably isn't required for such a simple task because the camera should be able to connect directly to the servo controller. A good motion controller is progammable and can the data downloaded by the camera to do what is needed. As for the sero and drive, many brands will do. More information is required to determine the size.
It should be added that in case of Cognex, Modbus/TCP and Profinet communication available as well. On the other hand, if Omron vision system is considered as a possible option, it makes sense to look at Omron controllers as well.
Hi, did anyone try to drive Omron Smartstep servo drive by Unitronics Vision PLC? Sample code?
3,822
I have an AOI with revision notes. Someone entered the last note into the description instead of the notes. I cannot just click into the revision...
161
I have worked on small projects using AB Micrologix but now we want to take a photo, process it online, and sort based on returned variables...
338
I am working with Twincat 3. I am trying to store some images in files and when PLC restarts I want to read those files and get the images...
59
Hello all, I have been tasked with flashing our processors to the newest version of Studio 5000, and have downloaded the DMK file for the...
259
