Hi Everybody,
I have spent lots of time trying to find some info online and read some very interesting topics here but just hoping to get some advice on a project of mine so any help, advice or pointers would be hugely appreciated.
I need to set up a vision system to read the angle position of a part on a conveyor, I then need a stepper/servo motor system to re-orientate the part to 0deg. This is a part of a college project so I'm hoping to keep it as simple and cheap as possible. I will be using cognex vision system and either RsLogix or Siemens S7 plc which I have access to already. The vision application should be straight forward enough I hope but I'm hoping to get a recommendation for a cheap, user friendly motor system that will be relatively easy to configure to PLC/Cognex. The part to be orientated will be small and light similar to a coin, and the system will be a test rig set up so it wont be doing much work.
Just looking to get some advice on any particular motor/drive which will be easy enough to configure? and if anyone has done similar projects, if so is there much preference between RsLogix/cognex or Siemens/Cognex?
Thanks a million for any advice
