VLT_FC302 via profibus to S7
Nepiter
Apr 2010
At job
79
I have connected Danfoss FC302 vlt to profibus, and I'm controlling that with S7300. Ppo type is 6.
I am able to start and conroll vlt.
But when I try to read reference[unit] from vlt, something goes wrong.
Example:
I will set speed to 5hz.
VLT shows at the panel: 4,999hz.
I will get 4999 to db1.dbw0 (value moved from pew292 which i have choosed to receive reference[unit])
Everything is ok, until i jump over value of 32hz..
32Hz gives me value of 32001. That I can handle..
But, when I set speed to 33hz, value jumps to -32534 at db1.dbw0..
34Hz gives -31533, and so on..
How could I convert this value to show same value as I have set..?
(If I move pew292 to db1.dbd2 (double word) I can reach value of 64, and after that, value jumps again to minus value..)
o_O
Word = 16 bits = 16 bit integer = range from 32,768 to -32,767.
Either set PEW to PED, or change the scaling in the FC302.
..That was exactly what I was thinking..
But, I could not understand that I need to reserve two words from VLT, to send reference to PLC...
I just thought that if I reserve 1 word for "reference[unit]" VLT will send everything what fits in to that word. And if I choose 2 "reference[unit]", I will receive twice same information in two words.
But it was not like I thought..
Now I have reserved 2 words for "reference[unit]" at vlt, and I am reading PED, from at CPU.
Yes, now it works nicely!!
Thank You!! :D:D
Hello and good morning experts, I have a question, how to use the "VLT5000 conversion wizard" of the software MCT 10?. I searched in the manual...
1,568
Sorry to ask guys. I am workign away from home at the moment overseas and have a time difference to my supplier. Anyone know where the setting...
40,166
Hello all. I am hoping someone here has installed a Danfoss VLT Midi FC 280 and connected an encoder to it. I am just trying to make sure I select...
464
Having a small problem with a new danfoss micro VLT FC51 drive I was hoping someone on here could help with. my setup: my motor speed is...
1,417
Hello everyone, I am an engineering student who took on a project to design and build a control system for an industrial coffee roaster as my...
4,504
