dcooper33
I think I may be the only controls guy out there nutty enough to attempt this! (At least according to the RA Tech Support guys I've baffled today )
Suffice it to say that connecting to our controls network over WIFI is an unavoidable necessity at this time.
The set-up:
Large controls VLAN that all of our PLC's reside on (10.44.2 xx)
Larger corporate network, spread across several plants, that our FTAC server resides on.
Through a managed switch and gateway on the controls VLAN, the FTAC server is allowed on the controls network. This is the only corporate IP that has access.
The support PCs connect to controls net via wireless router, and to FTAC via gateway. No problems.
Now the new wrinkle: We have new support PCs that run Win 7 64bit, plus dozens of PV+'s running 5.10 fw, so a 32bit VM is necessary, at least for FTVIEW studio.
So on the VM, Iwas able to iinstall all of my requisite RA software, including FTAC client with no issues. I am using the vmnet8 (NAT) adaptor and the host OS is connected to WIFI network.
From the VM, I can ping and remote into the server. I can go online with PLCs. I have remote server configured as network directory host. But I can't open FTAC client. After 5-10 mins I get an error msg saying "Failure Initializing Application Eventing Subsystem"
Also if I open the FT Admin Console on the VM, then I can receive the current configuration from the server, but if changes are made on another PC, then those changes will not appear in the VM console until Admin Console is restarted. If I make a change to the config FROM the VM then those changes will appear on the network immediately, but again, they will not show up in the VM console until it is restarted!
I have RA and Vmware support both looking into this, and both sides are baffled (and vaguely insinuate the other software's responsibility )
RA finally said that they always run a physical LAN connection bridged to the VM, and don't mess with wireless. I can understand why, but that isn't helpful to me obviously.
It's extra frustrating because I know SOME comms are open between the VM and the server, just not enough... I am suspecting it is some kind of port conflict issue, but I'm not savvy enough to dig very deep on it. My plant IT guys weren't much help in this case either.
So, if you're still reading, thanks :grin: If needed, I can draw up a quick network map if it will help anybody. Bear in mind, though, that FTAC client is working wirelessly with over a dozen other PCs on the same network (All Win XP boxes, not in a VM) .
Thanks,
Dustin
The set-up:
Thanks,
Dustin
