VMware and Tia portal
treellama
Jan 2016
Delaware
39
I've had a lot of problems with Tia Portal pegging cpu usage at 100% in my VMware machine. It got so bad that I instanced a fresh VM with windows 7 and installed only Tia Portal V15, but I continue to have the same problems. I've updated to the most recent service pack.
I run VM's for other software and haven't experienced the same issues. Does anyone have suggestions of settings to tweak to get it to work better? I'm just doing PLC / startdrive config
I have a windows 10 host, windows 7 pro VM
VM settings:
8GB ram
1 processor core
Intel VT-x enabled
110GB hard drive space
network adapter in bridged mode
Thanks!
I have:
16 GB RAM (out of 32 GB on the host).
4 cores (out of 8 cores on the host).
250 GB HD (out of 1 TB SSD on the host).
Runs reasonably well.
8 GB sounds as too little.
SSD disk makes a big difference. Dont even try with a regular spinning HD !
This is not a direct solution for your problem but it can be intresting hearing my specs i run my TIA VM session on:
Host: Windows 7SP1 Pro
VM: Windows 7SP1 Pro
9.5GB ram
2 processor cores
Virtualization engine : Automatic.
Hard disk: 120GB
I have no problem with the CPU usage while working in the VM-session.
//V
VM settings:
8GB ram
1 processor core
Intel VT-x enabled
Thanks!
Your system is similar to mine which I know is *not* very good but I tried both VMware and VirtualBox and found the latter to perform better with my limited resources.
I use Tia 14 and 15 in VMs. I use virtualbox and vmware exsi. Both work fine.
You really need atleast 2(I prefer 4) cores or more allocated to the VM, don't starve the host though. 8GB should be more than enough ram, add more if using simulator. Again leave enough for the host.
Put the VM on a SSD drive or a drive that isn't used for the operating system. Huge difference.
Make sure virtual extensions are enabled in bios.
Don't run virus scanner on the VM folders.
I can run TIA portal, simulator and visual studio all in the same VM. And I am using 6 to 10 year old computers and servers to run this on with 3 monitors.
I think my patience should be commended... I run a copy of V15 with about 4G RAM and one core.
Yes, it is slow, but usable. Although PLC Simulation is impossible and I suspect running HMI's too.
Thanks everyone! I switched to 2 cores today and it made a huge difference. Highly recommend. I kept the ram at 8, because I haven't approached that limit yet in task manager.
Next time I switch hard drives, I'll switch to an SSD. I use one for my host OS, but my VM's run from a second internal drive.
HI, I'm running TIA Portal V13 SP1 Update 9 on a virtual machine, but having some issue with TIA Portal crashing. I'm just wondering if someone...
3,433
Greetings all. I am having a new problem with my VM. Host OS is 11 and VM OS is 10. I have two smaller monitors that connect to my laptop which...
583
So, I have a little dillemma I am trying to work through but I feel there is probably a better way. I've always liked the idea of using a VM in...
2,055
*VMWare vCenter Converter Standalone version 6.3 & 6.4 Hello Experts I want to convert my current physical hardware machine to a virtual...
1,630
Hello Hivemind My wife has a legacy machine at her work which uses (or I should used) an XP desktop with a serial port to communicate with a...
1,089
