VMWARE Networking question
fj1200
Jan 2008
Cambs
I have a PC that I want to run under VMWare GSX server. The PC has 2 NICs and is running RSLinx connecting directly into a PLC rack on one of them. On the server I want to run it on also has 2 NICs. the way I want to run it is for one of the NICs to be bridged to the corporate LAN and the other to patch into the PLC rack, but I can't get that bit to work. It talks to the company LAN ok, I can ping everything ok etc, but the PLC side won't work at all. the driver under RSLinx looks for an ip address on the rack, and is on a different subnet to the other NIC. so for example, the corporate LAN is 192.168.0.1 and the rack is 192.168.2.1. I need the 2nd NIC JUST for the PLCs and nothing else, does anyone know how I can lock the VM NIC to the physical NIC?
Greetings all. I am having a new problem with my VM. Host OS is 11 and VM OS is 10. I have two smaller monitors that connect to my laptop which...
583
So, I have a little dillemma I am trying to work through but I feel there is probably a better way. I've always liked the idea of using a VM in...
2,065
*VMWare vCenter Converter Standalone version 6.3 & 6.4 Hello Experts I want to convert my current physical hardware machine to a virtual...
1,637
Hello Hivemind My wife has a legacy machine at her work which uses (or I should used) an XP desktop with a serial port to communicate with a...
1,090
I have a MacBook running Monterey. I have a VMWare Fusion virtual machine on it running Win10. On the VM I have the Rockwell toolkit loaded. I...
3,054
