voltage divider question
ascot01
Jul 2007
Magnolia, TX
81
I have a de-ionization meter measuring TDS in megohms.
The analog out for remote monitoring is 0-10 vdc.
The monitoring controller input is 0-5 vdc.
Is a voltage divider what I need here and does it work on analog signals?
If you put two equal value resistors in series and then tap the center point between the two, you will get exactly half the voltage.
So if your signal is sourcing it would look like this:
..........................1000 ohm...1000 ohm
Analog output------ZZZZZ------ZZZZZ-------Ground
.................................Analog Input
The 1000 ohm is just an example, they could be any value.
I disagree. The size of the resistors is important. The input resistance of the Analog Input is across one of the resistors and will lower the effective resistance of that resistor giving a ratio less than 50%.
Make the total resistance of the resistors slightly more than the minimum load resistance of the Analog Output to get highest accuracy.
I am trying to look at two input signals on a servo. The inputs are 24V DC but my data logger is only 2.5 volt in. Does anyone see a problem...
1,669
Hi there, Interesting problem today. Been fiddling around with a Click PLC. I have an extension module for it. A combo discrete 8/8. I am trying...
1,742
Could someone say if this will work? The datasheet suggests that when it sees 33V or above, the ingital input is ON and for any voltage less...
4,563
Hello all- I have a unique challenge using a customers Direct logic 06 PLC. This customer has a DC motor operating at 10 RPM which is turning a...
138
I've got 6 identical regenerative vacuum blowers powered by 6 identical drives in 3 identical panels all fed from the same 1 main building feed...
27
885
