I was called out to look at a machine, where the customer was complaining about voltage spikes on the ground wire going to an ampliphier card. I thought it would be an easy trip, I expected to see a clutterd panel, with no shielding, and wires runnining every which way. This turned out not to be the case, and it turned out to be more than one machine. The customer has been burning up the ampliphier cards, about every 3 to 4 months. The manufacturer of the card evaluates why the card has failed, and has indicated that it is due to voltage on the ground terminal. The card is fed with 24VDC, to power the card, and receives a 0 to 10VDC signal voltage from an Allen Bradley analog output card.
Measuring between OV, and ground you can see votage spikes, somtimes as high as 16VDC, when the E-Stop is actuated, and when the machine is first powered up. The machines all have about 15 to 20 DC relays, and some DC safety relays. There is only one main DC power supply, and the OV return wire is bonded to ground. The customer has tried powering the analog module, off the backplane of the PLC, and externally, and it doesn't seem to make a difference. We are measuring these spike right at the terminal blocks which feed the analog signal to the card. The wiring in the panel, is great, everything is shielded, and high, and low voltage is seperated.
Any ideas, or thoughts would be greatly appreciated.
Thank you.
Thank you.
