WAGO 750-8212 SYS Led blinking orange
Radityo
May 2023
Seoul
I'm new to working with PLCs and I'm experiencing issues with my WAGO 750-8212 device. When I attempt to turn it on, the SYS LED (orange) only blinks, and the device does not appear to working correctly. I have attempted to perform a factory reset, but this has not resolved the issue.
Could you please provide me with the guidances on how to resolve this issue?
Thank you
F33D5373-1B8B-4B30-B34A-552BC6EA70C7.jpg 878933BE-F14A-4CA1-88BE-50346F292143.jpg
Thank you
The attached picture explains the states of the SYS LED of the WAGO.
The problem is apparently with a mode called "Fix IP Address". I guess that you set the controller to that mode by pressing or holding the RST button.
It basically sets a fixed IP address to the controller and you should be able to connect to its webserver. The controller and the your computer must be in the same subnet.
You should look it up in the manual which you can download from here.
Best Regards
Konstantin Kolev
Hello, I am in possession of a WAGO PFC 200 750-8216 which I was successfully able to set up as a Modbus RTU Master to a slave device using...
104
I have a project to setup base programs across multiple PLC platforms that can be used for Modbus communications to various sensors that have...
141
Hello, I m having a problem with wago 750-862 plc. The plc won't start automatically in run mode after a power reboot. I've also tried the...
422
Hello everyone, I am trying to setup a Wago 750-8100 PLC to send a text message out via ethernet port, if I get a Digital input that is true. I...
368
Hi, I have never used modbus communication in Codesys 2.3, any tips and tricks are much appreciated. The system is a Wago 750-881 that controls...
1,907
