WAGO BTEG help
ceilingwalker
Mar 2010
Phoenix, AZ
1,586
Hello. I am hoping that others here have set up wireless gateways, using a WAGO BTEG part number 758-918. I believe I have it all wired correctly, following the guide and I believe I have autoconfigured it correctly however, I am not sure. I have 2 WAGO's connected to the same ethernet switch at my desk, to set this thing up. I looked for a tech support number however, they all appear to be in Germany, and would no doubt be closed at this time. Any help would be awesome. Thank you.
Hello, I am in possession of a WAGO PFC 200 750-8216 which I was successfully able to set up as a Modbus RTU Master to a slave device using...
86
I have a project to setup base programs across multiple PLC platforms that can be used for Modbus communications to various sensors that have...
122
Hello, I m having a problem with wago 750-862 plc. The plc won't start automatically in run mode after a power reboot. I've also tried the...
356
Hello everyone, I am trying to setup a Wago 750-8100 PLC to send a text message out via ethernet port, if I get a Digital input that is true. I...
346
How do you set up a message block for a REMOTE IO unit? (using ethernet IP)?
595
