Way off topic - RS232 Filter?
Steve Etter
Apr 2002
Morristown, TN
965
Hi all,
This is way off topic, I know, and I hope y'all don't mind too much, but since it is communications related I thought it might be Ok.
I recently "fried" a CNC machine (~$9,000 worth of repair) when I replaced a UPS on a peripheral PC that is used to store parts programs. This PC is connected to the CNC via an RS232 cable and there is a small application that runs on the PC to suck the parts programs from the CNC and store them on the harddrive and then to poke them back into the CNC when needed.
Talking to the tech support guys from the CNC manufacturer, I am told that the serial cable between the two should remain disconnected whenever uploading or downloading is not happening. Had this been the case when I attached the new UPS, they say, the problem would not have happened (Yeah, right). The reason for keeping the cable disconnected, they say, is to protect against the effects of lightning, etc.
Anyway, this is a plant-floor machine. The PC is right there, on the plant floor, at the machine. The guy who uses it is the machine operator and he needs it when he needs it. What he doesn't need is to have to attach and disconnect the cable every time he uses it. I have no doubt that the cable will remain attached eventually.
Ok, finally...my question: Does anyone know of some kind of filter/buffer that goes inline with serial cables to protect against spikes and such caused by lightning, etc.? As far as liability is concerned, I am pretty sure the CNC manufacturer will not recognize anything short of their recommended procedure, but I cannot live with this procedure, either. I need to find some sort of reasonable way to realistically reduce the machines exposure and keep the cable attached at both ends.
Thanks,
Steve
Steve
As Ron stated above go for opto-isolation, but I thought that most 'modern' rs232 ports are opto-isolated as a matter of course, I might be wrong on this front, I await to be put right on this matter.
Paul
Looks Perfect
Thanks Ron,
This looks like exactly what I need. I will even try to get the CNC man to agree to it.
PLucas...Never heard that before, but then again, I never heard the opposite either.
Thanks.
Steve
Steve
I am sure that the ports on my laptop are opto-isolated and I am 99% sure that the rs232 port on the siemens CP340 comms module is also opto-isolated, so that is what I am basing my limited knowledge of our friendly 232 ports on
Paul
My experience is the opposite... I've seen laptops fried because they were plugged into their wall socket source which was on a different ground than the PLC on a machine.
B&B Electronics are my source as well for this sort of thing.
For a great technical overview of serial device isolation, read through Lynn A. Linse's tutorials at:
http://www.robustdc.com/
The Siemens CP340 comm port is galvanically isolated, the laptop may be but I would take time to triple check that because it is not a common feature for any computer system. I have fried alot of older computers playing around with things from the serial and parallel port. I have also seen laptops fried when connecting to things in a plant.
This is the motor nameplate from one of the powder hoist motors on the USS Texas an older generation battle ship, built in 1911-1914 ish. The...
295
Totally off topic, but strange observation. I purchased a few cisco ethernet switches off of ebay some years ago. They are part of a home lab...
2,080
Good morning, Please excuse me if this is too off topic here, but it is a programmable controller of sort. I have an Omron ES100P temperature...
2,344
Which way is up and what's that strange looking bug? I was trying to login to micro_cr*p team_Shi* and it wouldn't let me because I exhibited...
2,708
Hi folks, I have a hydraulically driven rake in a clarifier that rotates at about .18 rpm. When there is a process upset, the bed of the...
3,732
