web server for compactlogix L16
Jyonny
Oct 2015
East coast
21
Hello guys,
I have a compact logix 1769-L16 connected with a Panelview 800.
Everything is working fine, but I would like to add the feature to connect to the plc via other devices (mobile devices).
Panelview 800 has the possibility to communicate via VNC but there is the limit of 1 connection per time.
Do you have any other idea?
I am looking for a web server where I can make xml/html pages and let users in the same network to communicate via browser (with mobile devices).
I have never tried 1768-EWEB module but I think it is not compatible with 1769-L16 processor.
Thank you in advance.
Jyonny
The way that I have done this in the past is to communicate to the PLC and store the information into a database.
This can be done by using AdvancedHMI.
https://sourceforge.net/projects/advancedhmi/
Now turn the windows based computer into a web server (IIS). This is done by adding the windows component.
Turn on ASP (ASP.Net) from the web server.
You can now write your scripts to display the information in the database or write back into the database.
http://accautomation.ca/now-you-can-have-robust-data-logging-for-free-part-1/
All of this can be done without additional expenses.
This is just a general guide.
Regards,
Thank you for this solution,
I didn't know it.
If you have another ideas without installing a computer please let me know.
Hi. I’m trying to figure out a way to pull the logged data from a Red Lion Graphite 07C0000 HMI and display some trends on a web page. Something...
1,037
Hi all, Summary I am stuck at what I hope is the last step (see below) in trying to look at [Data Views] via a MicroLogix built-in web server...
1,699
So the micrologix 1100 has a built in web server. I have been following the user manual 1763-UM002. After I enter in my controller's IP address...
1,196
Hi New to the form but have been a lurker for quite a while. Wanted to get other users thoughts and see if there are any reliability issues with...
4,096
Hi, I log into a csv document on a USB stick. We have a VPN so that we can (should be able to) download it remotely. But when I try to download...
1,738
