Webcam Feed on Win CE
NH-Thor
Oct 2018
Aarhus
How to get a low delay webcam feed into a HMI/Industrial-PC with Windows embedded, or factory talk ME.
like
This beckhoff Industrial PC
or
A Rockwell panelview like this
Keep the following in mind:
  • The solution has to be able to talk to a Allen Bradley compact logix.
  • video feed from USB or IP cam.
  • A low delay of the feed from the webcam to the HMI/PC.
  • Drivers are hard to find for windows CE
If you have any solutions, even if its not like what i have set up please post it!
What do you mean when you say a "low delay" webcam feed? Would, say, 1 second be acceptable delay? I haven't seen many realtime videostreaming systems, there's usually some buffering to make it look good. Using webcams for things like quality, part present, or maybe doublechecking alignment is OK, but I wouldn't ever recommend using them to give the operator a view while jogging a motor left/right.
If that lines up with what you're trying, the Comfort panels from Siemens could be a good match. A solid HMI, and way cheaper than a panelview.
To ensure skin is alined in a tan machine. Right now there is a mirror, but you want to replace it with a video feed. if the delay does not get too long.
Thank you for your reply mate!
Hello all, I'm looking for ideas or solutions on having a industrial webcam or IP camera that we could use on our equipment to help monitor and...
1,219
I've been looking all over for information and it's paltry at best. I'm looking for a setup that will allow me to have a webcam (either USB or IP)...
10,877
Hello, I am using SCADA Cimplicity and I want to import a video window in a cimedit screen from the webcam attached to my PC. Does anyone now...
1,310
Has anyone successfully linked a USB WebCam to Redlion G3 HMI (preferably using Crimson 3)? :hmmm: If not, Is there any plans in the future, to...
5,872
Hi guys, I am new to PLC CitectScada. My supervisor requests me to embed several webcams into my scada. The webcams will be used to monitor all...
4,095
