Embedded Webcam into CitectScada
Aug 2010
WA
Hi guys, I am new to PLC CitectScada.
My supervisor requests me to embed several webcams into my scada. The webcams will be used to monitor all three PLC tables (distributing table, testing table and sorting table)in our lab remotely.
Just wondering does anyone know how to start the project?
regards,
Charles.
Check w/ Citect to see if there software supports displaying a mjpeg stream.
If it does, you can use any network based IP cam that will do mjpeg.
For example, I use the Axis 223M's here on plant. I have the cam display inline on my furnace process(I'm not using Citect however).
You can embed an ActiveX window in a page and point it to the camera with a script on the page entry.
RE: BTalbot & Dravik
I had a look at MOXA website, the method shown in MOXA is by using an IP camera. An IP camera will not work in my case because the CitectScada is running in my university which means the IP camera need to be connected to my uni's WIFI or LAN. So, it will be hard for me to obtain the IP address from the uni's network. Thanks.
Is there any alternating way of doing it? thanks..
RE: bazzab1
I think activeX might be a better option? BUT I know nothing about activeX, script and stuffs. May i grabbed more details from u like where to start and how to do it? Thanks.
http://www.plctalk.net/qanda/member.php?u=43061
Unfortunately the last time I used this method it was with IP cameras. In 2006 I used ActiveX with "Winnov" video cards (4 X coax inputs) to embed video into Citect (V5.5). The people at Winnov were very helpful and I would contact them to see if they have any ActiveX components for their newer cards.
The active X is the way to go, but you don't necessarily need to purchase hardware. There are software vendors available that you could buy it from.
Hi Guys,
Since Citect SCADA is already under Schneider Electric, the easiest way to implement your project is to use Pelco IP cameras using ActiveX. By the way, Pelco is under Schneider too, that's why they made a good collboration. Pan, tilt, zoom of your camera will be incorporated to SCADA.
Warm regards,
hi guys,
i already had my IP camera, can anyone show me how to embed it into my CitectSCADA's GUi..?
I have tried the methods shown in moxa but it doesn't seems to be working properly.
your helps is much appreciated.
regards,
Charles
Hello everyone! This is my first time posting, though I have been to this site a few times hunting for some random problem like we all do. I...
174
Hi Guys, I have a 1769-L24-QBFCB1 that has the OK light flashing on the embedded counter module. The manual states it is a resettable fault, but...
109
I am using Allen Bradley PLC for Ethernet/IP communication. I send any explicit msg request (Get attribute or Set attribute), I observed packet...
77
Hi everyone, this is my first time trying to setup encoder counts and track the traveled distance and speed i am using L27ERM QBFC1B processor...
391
Hello all. I am trying to get an encoder connected to an embedded HSC on a 1769-l24er-qbfc1b. This is how I wired it in but it isn't working at all.
958
