What are S Bits?
kevintfa
Jun 2005
Windsor, Ontario CANADA
22
Good mrning all!!
I have come across a program on a SLC 500 where there is a bit called S:103/5 with no description of any sort. I looked it up in the data files under S2-CPU status and found it on the usage page marked with an x. Does anyone know what it is?
It is located on a rung between an OSR bit and a OTL bit.
Any help would be much appreciated!!
That is a very high word in the status file... You need to look up the status file FOR THAT PROCESSOR. SLC's and micrologix have different status file lengths and layouts.
Snakes eyes on Indramat Power supply
We have a problem that occurs on our Indramat KVR 1.3-30-3 POWER SUPPLY'S. When the power to the unit is switching on and off frequently, we get a power failure and 2 blinking dots in the display window. Indramat responded by saying "we have never heard of this" The code is 01 power off, The only way to clear the blinking dots is to cycle power. This happens during set up when people are in and out of the light curtain and power is swithcing on and off frequently.
Has anyone heard of this problem? Any suggestions would be appreciated.
Kevin,
this probably has nothing to do with your post on the power supplies ... but ...
based on what you’ve posted so far, here's my best guess about the "S:103/5" question ... I think that the original programmer was checking the information from station/node #03 on the DH+ network ... this is part of the little-known (and under-used) “Global Data” capability of the SLC-5/04 processor ...
basic idea: the “Global Data” feature allows you to broadcast one 16-bit word over the DH+ network for “free” ... specifically, no MSG (Message) command is needed - and no additional network traffic is created ... note: PLC-5 processors can do this too ...
That makes sense since there is a laser welder connected to the network, and it looks like the bit is on when the beam is on. Thanks for the info, I had never come across something like that before!!! As far as the power supply post, it was supposed to be a new topic, but i was in the wrong screen...UUPS
Thanks for your help!!!
Hi I am being given several fault words (as a DINT) from a Drive that I am receiving into a Compactlogix L33ER controller. I have a small...
1,143
Dear Fellows; I am working on a very old machine which is designed in GE 90-30 PLC system. I have some difficulties like 1. How a force to...
352
Hi All, I am trying to write some simulation logic for an existing project im working on. Does anyone know if this is possible to write to...
1,279
Hi, I have this code: LAR1 P##structy L 0 T LW [AR1,P#0.0] which resets all the bits in this struct called structy...
643
I am passing DINTs between a Micro800 and CompactLogix - each bit in the DINT has its own unique meaning. On the Studio5000 side I can just write...
1,105
