What are the cause that make controlnet card fail?
chatree
Jan 2014
thai
I added new controlnet's rack Remote IO to the existing system and It already work well then about 10days later. There was one controlnet's rack fail(the one in the existing system) and that rack couldn't control or monitor with RSlogix software. I tried to turn power off and turn power on again then It work. What are the cause that make controlnet card fail?
Thank you in advance
More than 95% of the time, a failure on ControlNet is poor cable installation. Check that first. Do NOT use budget BNC connectors or cable, and make sure you have the proper terminations at each end of the coax link.
If actually the communications card did fail, well, things fail. Even there, it is usually that the BNC connector on the card was damaged from someone yanking on the cable, or dropping the card.
Swap in another card, see if that works, if all your cabling is good.
Or, sometimes what used to be called "infant mortality" ( Don't know if you can use that term any more)
If an electronic component is going to fail, it will usually do so within the first few days of constant use.
Hi everyone, I need a solution based on the cause and effect diagram, especially a macro sheet or VBA script in Excel, which will help me generate...
78
Good Morning , Not sure how many use Markem-Imaje SmartDate X60 Printers , but I'm having trouble finding a good manual for...
629
Hello everyone, In the designer softwar of the plc HC900, I used the function version control on the toolbar and it deleted files from my...
358
Good Evening , We had a Mettler Toledo Safeline Metal Detector acting unstable last week . We brought Mettler Toledo in to look at it ...
839
This is a program in a machine that has been running for about 7 years without any issue like this. We have a master servo (the machine's main...
1,171
