Jim Dungar
Yes, that is what we say in power systems analysis.Gilbert W said:So you’re saying that as the magnetic field passes through a wire as it does in a generator winding, the phase relationship between the ends of the wire is that they are in phase? Is that the correct terminology?
Yes, this is what a sine wave looks like. But in power systems we do not deal with the peaks of the wave form. We use average RMS values to represent the length of our "voltage" line (you should find information on phasor and vector analysis). If we have multiple waveforms the difference in the zero crossing points (negative going to positive) becomes our phase difference. One voltage waveform means one phase.I was under the impression that the “other end” would swing both positive and negative and not just in a single direction, and if we are talking 60 Hz, the positive and negative peaks would be 8.3 mS apart.
Choosing a new reference point somewhere along a single straight line does not change the relationship between the the end points of the line. Given the two ends of a line as B and E, their relation ship doesn't change simply by adding a new point M between them. Yes, there is now a B-M and a M-E but they must still equal the original B-E result.I was also under the impression that “choosing a reference point” shouldn’t “force the other end” to change in any way. Can you give me some insight on what exactly you meant?
There is very little difference in the analysis of DC and single phase AC circuits.I didn’t understand your comments about a battery or power supply either. I was under the impression that to have a phase relationship, at least one entity has to go “Full Circle” and return to it’s starting point on a consistent basis as the waveforms from a generator or transformer might do. I didn’t understand why you were using DC components in a discussion about AC phasing. Can you tell me why you used those examples and how they relate to AC phasing?
If you have multiple voltage waveforms then you may have a poly-phase voltage system. This is one use of the word phase.
If your voltage waveform and your current waveform have a time difference in their zero crossing points, you have another use of the word phase. Can you have a this type of phase relationship in a DC circuit?
