What is it's mark
xblackx
Nov 2007
izmit
hi all friends
What is it's mark? Please help me
bestregards
I know that Siemens did have a OP20 but I'm not sure if this is it :( Doesn't really look like it would be a Siemens OP but that might be because of the photo
EDIT: Looked at the OP20 of Siemens and it defenetly does not look like this one :(
It looks like a VERY old Optimate OP-20 panel, made by Koyo in Japan. This brand is sold in the U.S. as Automation Direct. The Optimate model split into two categories at some point. It became the EZ-Text panels and the Optimate Panels. The EZ-Text 220P below is very close (FUNCTIONALLY) to the OP-20 in the posted picture, BUT it is now obsolete.
http://web2.automationdirect.com/adc/Shopping/Catalog/Operator_Interfaces/EZText_Panels/EZ-220P
The Optimate 1000 series (link below) would be about as close a replacement as you could find now. The OP-1500 has all the features of the OP-20, except the menu scrolling keys. The UP and DOWN Arrow keys on the OP-1500 can be programmed to SIMULATE the menu keys on the old OP-20.
http://web2.automationdirect.com/adc/Shopping/Catalog/Operator_Interfaces/Optimate_Text_Panels/Optimate_1000_Series/OP-1500
AEI Service said:
Can you give any more info on the unit?
Type of machine it is on or age?
Paul
hi Paul
Anything isn't writing on it :( my fiends thank but it isn't these
best regards
Xblack,
What year was the OP-20 installed?
If nothing is written on it, how do you know it is not an Optimate?
I make a guess of 1990 or before. It appears to be an old obsolete Optimate, for which you can no longer find information or buy new.
Optimate might have some old instruction manuals, if you could contact the right person.
Greetings. I want to install a PLC with servo and photocell. For a plastic bag cutting and sealing machine, logically it will work with printed...
123
I'm having an issue where there is a yellow question mark for the 1756-enbt/a. I've installed the EDS file along with uploading eds from device...
1,122
hi, im currently programming on fuiji spf plc with colour mark sensor,while running it returns a nonfatal error which disables the mark interupt...
549
As far as I know the UKCA mark is mandatory from 2023, and that is 9 months from now. That is not a lot of time to investigate, design, validate...
22
4,762
Hello. I have a PV7, using FTViewStudio v.12. When I load the .mer I get "?" instead of text. I haven't had this happen to me before when it comes...
1,699
