what is the difference FX3U-ENET L and FX3U-ENET ADP
harrydeharry
May 2008
Delhi
237
can some one clearify what is the difference between FX3U-ENET L and FX3U-ENET ADP, since we have to use a vision system of congnex on and the camera supplier says that it will only work with ENET card not even with the 3GE PLC.
thanks in advance.
We have remote IO 1734-AENTR and all of them seem to be recognized in Logix except in, RIO-5000. When we look at the revision, all the ones that...
748
From a FAT it appears that a struct containing bits/int/real can't be sent from a 1513 to a 1200. When using two 1513 there is no issue. Total...
700
Hello, I have a problem with AO- and AA-Tags. When I use for example the tag AO_Test with the address 200 and type the value 1,2 in, the AA-Tag...
1,421
Hi; We installed an orifice plate type steam flow transmitter which configured to give 4-20mA signal correspond to 0-9ton. I given that signal...
24
5,630
As per the title. This might seem like a basic question to many, but I'm unclear about the difference between a coil ( ) and an application...
28
4,052
