Whats needed to build WinCC terminal?
leem2209
May 2015
Wirral, UK
210
One of the things I really want to learn more is creating and editing visual screens on WinCC. I'd like to have a PC and test PLC set up to play about.
I realise I will need the WinCC software, but what about hardware?
Do I need any hardware components for the PC or can I connect over Ethernet to an Ethernet CP card on the PLC?
Or, can I make use of the old Siemens PG I have and connect over MPI via the CPU?
Thanks for any pointers on this....
Mark
I am guessing that you mean WinCC in TIA, not old WinCC v7, or ... ?
Definitely go all-ethernet if possible.
No need for special ethernet hardware. A regular ethernet port in the PC will do.
For WinCC with TIA you need a reasonably uptodate PC, with a not too small display.
SSD will be a big plus.
Forget the old Siemens PG.
so after a previous thread about the panelview 1200. I figured everything out that I needed to get working with it. I've got the RIO discrete...
1,580
Good Morning, I am building a panel that has 120VAC, 24VDC, 12VDC, and 5VDC, and was wondering if anyone had any ideas for wire colors. I have...
3,109
Hello everyone, So I need help setting up traps in Studio 5000. Disclaimer I'm an intermediate PLC programmer so I need lots of help and I need to...
2,337
Hi Replaced an faulty AI module (331-7KF02-0AB0). When Inputs connected smoke was rising from the card. Got afraid of sinking the whole node...
1,626
I have to put 3 UPS's into outdoor cabs. I thought of going with the ones that are used on Traffic lights and such but that is such overkill for...
2,525
