What's the coolest control panel/HMI ever built?
They build that to withstand someone trying to break it. What happens when they get a new operator in the plant that has never seen an automation system.
Some of these new guys and gals could do destructive testing on a forged anvil with a feather duster and leave nothing but forging dust to blow in the wind.
It might take water, hammer blows, and a shotgun blast, but it's still only stagehand RESISTANT. They can destroy anything... quickly.
leitmotif, I see your sanitation crew and raise you one "Mongo the Stagehand."
-rpoet
leitmotif, I see your sanitation crew and raise you one "Mongo the Stagehand." -rpoet
Stagehand has absolutely nothing on a food plant sanitation crew. I got 5 aces.
Dan Bentler
Dan Bentler
I would second that. Never underestimate the power of a Jet Washer. I have seen one of our cleanup crew remove the touch screen membrane from the front of a Panel View with one.
+1 on sanitation (hygiene team) ours can fill IP67 sensors with water (submersible to 3 feet)
I think they feel its a challange to destroy anything that runs on tingly stuff
Steve
We have four machines (Pacmac) with those touchscreens on them. We have only replaced one in the 6 years I have worked here, and it had a problem with a printer port IIRC. Too bad you can't load them up with Crimson. I think they run XP embedded or a custom DOS based HMI package.
+1 for the food sanitation crews.
My guy's here in the plastic's industry are no joke either. I would put them up against any small army.
I have yet to find a device they can't destroy.
I came in one morning and saw a night shift production guy doing pullup's on a 1 1/4 rigid conduit that was about 8 feet off the floor going to a disconnect.
We walked him out the door shortly after 9:00 when HR get's here.
http://www.eurotherm.com/products/controllers/penguin/
I have not used these, but I think its cool.
Of the HMIs I have used , I like the Unitronics, but only because they have a PLC attached and the software is free.
Textiles machine operators are the worst I have ever heard of. Management had to pay them a production premium to stop them from destroying everything.
The above HMI is certainly impressive and would frustrated many workers looking for an extra break.
I’m attempt to establish a communication between two simulator M580 CPUs, using a READ_VAR, I have two vitalization Windows 10 in VMWare and each...
42
Adding ethernet equipment to an existing panel that has none. We have some solid ethernet cables coming from other remote cabinets that I plan to...
124
does anyone have an install or know if/where i can download it for the following "ABB PS501 Control Builder Plus V2.3 " the software was a free...
90
I am not sure why this is requested, but it was asked. Currently I have one PLC , with one output to a relay, turning on a field equipment (just...
218
I have been requested to test this proportioning valve for PLC control of flow/pressure. Dwyer Series SVP Proportioning Solenoid Valve The flow...
422
