whats this?
Buddha
May 2005
21
Hi there i have a program where i wanted an output to come on after 10 seconds then go off again after another 10 seconds I was using someting (dont know if its a counter or timer!!) M474 and M475
, I want to be able to use more of these can anyone tell me what is the range of M... that I can use. (if ucant understand what im saying please tell me) I mean theres a M474,M475, IS THERE A M476, M478 ETC, If so what do they go up to?
I am using the PLC Mitsubishi F series and simple lamps and switches are used to represent the ourputs.
If it won't cause you all kinds of pain and grief to consider doing so...
...you really should get your hands on the manual.
Didn't the pointer from monkeyhead give you any help?
Hi Buddha.
What type of F-serie are you using??
The FX0 have from M0-M512, 63 Timers and 32 counters
The FX1N have from M0-M1535, 256 Timers and 235 counters
The FX2N(C) have from M0-M3071, 256 Timers and 235 counters
But if you have the old version of mitsubishi F1 or so, please let me know.
Dariusch
I dont know woud you be able to tell me if i tell you something from a paper ive got, here goes:
LD X401, RST C460, LD X402, OUT C460,K5,
LD C460 OUT Y431
HOPE THAT TELLS YOU.
so after a previous thread about the panelview 1200. I figured everything out that I needed to get working with it. I've got the RIO discrete...
1,582
Good Morning, I am building a panel that has 120VAC, 24VDC, 12VDC, and 5VDC, and was wondering if anyone had any ideas for wire colors. I have...
3,115
Hello everyone, So I need help setting up traps in Studio 5000. Disclaimer I'm an intermediate PLC programmer so I need lots of help and I need to...
2,339
Hi Replaced an faulty AI module (331-7KF02-0AB0). When Inputs connected smoke was rising from the card. Got afraid of sinking the whole node...
1,628
I have to put 3 UPS's into outdoor cabs. I thought of going with the ones that are used on Traffic lights and such but that is such overkill for...
2,532
