Will DLR work with Fiber
blawrenz
Jul 2006
Kansas City
22
I was wondering if anyone has any experience with setting up a Rockwell Automation DLR network and utilizing fiber between some of the nodes?
I am working on the layout of a new system that utilizes a Redundant 1756-L73 setup with approximately 23 Remote IO nodes that I intend to use EN2TR and AENTR modules. My problem is that some of the AENTR nodes are more than 100 meters from the next closest node so we plan to go through fiber converters and run fiber between the nodes to set up the ring. The Rockwell Manual that I reviewed indicated that fiber could be utilized between nodes but when I posed the question to Rockwell I got a response back saying that it would not work due to latency issues caused by the fiber converter.
Just wondering if anyone has tried and gotten a DLR to work successfully by utilizing fiber between nodes and if you have any tips on setting it up.
Thanks,
Brad
Thanks TWS,
I reviewed that document and found that it showed that fiber could be utilized. When I initially looked at it I did not notice that it said you had to use the 1783-ETAP device. So, I sent a question in to Rockwell and they came back and all they told me was: "It is not recommended to use media converters in the DLR because of induced latency on the DLR beacon."
So I thought I would post the question here in hopes that maybe someone has some experience in the use of media converters.
Anyway thanks for the reply!
You must use fiber converters that are designed specifically for DLR and certified to ODVA DLR spec compliance. These manufacturers usually have recommended beacon and timeout settings based on their testing.
Default beacon and timeout values calculated for copper only up to 50 nodes.
I would recommend to use ETAP1F that is designed for DLRs
Interesting, that reminded me of a project a few years back where the vendor used a pair of fiber converter and can't get DLR to work. Finally, they had to buy ETAP with fiber port.
Hello all. I need some help on DLR issue we encountered which is the DLR not working when supervisor is disconnected from the ring. FIrst of all...
147
Greetings Folks, This is my first post after a long gap (almost 13 years) on this forum and i hope that i will get things fixed with your...
310
Hello, I have a small DLR ring set up in a lab that consists of 1 Stratix 5200 and 2 ENTR/Cs. I am having an issues only on recovery of the ring...
181
Hello, I have been trying to figure out how to connect to and monitor a DLR that is on a remote rack from my PLC. The local has a 1756-L81E and...
129
HI I have a stratix 5700 switch 1783-BMS10CGA and I am asking if I can configure it to do a ring topology. So what can I do to configure it. I...
497
