Win10 & PVC C400
bbishop108
Mar 2017
Indiana
86
So I just recently got a new win10 laptop for work, and I just found out that win10 is NOT supported for connecting to the PVC C400, C600 using the mini usb connection and cable. Unfortunately I have not been successful connecting to any PVC C400/C600 HMI's with the win10 pc. Even using ethernet and trying to use the static ip address, and even the default ip address 169.254.254.2 does not work.
Has anyone been able to connect to these older HMI's using windows 10? If so, please share that magic trick. Thanks
I have a Win10 64 bit host for my OPC DA server, which is Indusoft (Studio,Scada.OPC.3). Locally OPC works, Matrikon OPC Explorer. On my Win7...
1,175
Greetings! I have had the extreme pleasure of being introduced to Rockwell's Win10-based PanelView Plus 7 and after having an extraordinarily...
2,381
Guys I know this may not be a PLC question but I do have a issue that I was needing some advise. I was needing to know the best way to create a...
1,941
I have a client who is looking to upgrade from Win7 to Win10, they're currently running NI Lookout 6.7.1 on the Win7 machine, it's a 64 bit OS...
1,281
I connect SLC 500- 5/02 cpu with 1747 UIC card to my Win10 pc using rslogix500/rslinx classic. There are four CPUs in a series.. if I leave the...
1,267
