WinCC Flex 2008 Item Won't show in the explorer Bar
enault
Jun 2008
house
35
The item that i create in WinCC Flexible 2008 are not showing in the Left explorer
I can only see the Template Screen, i cant see Script or structures
I can see and open Screen and Script by usint the Simatic Manager but i dont understand why there not showing in WinCC Flexible. For the Structures there is a big Problem because they are not available in the Simatic manager and they don't show in WinCC Flexible
I Wonder if anyone have seen this kind of problem.
I have attach image showing My WinCC Flex and an other of the Simatic Manager clearly showing that there actualy some screen in that project
I Hate so much when a software isn't design well enought to work correctly.
Just to Add a few Info I've try a few different Project and they all got the same problem
someone have an idea how to fix this or i should format and start over again?
i've found a way to access my structures using Cross-References
Im not able to make structure Copy
Anyway those item still wont show in the Project tree i guess its good enough so i wont format but its still kinda anoying
Under Options, Settings, Workbench, Project View Setting, Then i've set the value to "Display all item", and all My structure, Screen and script came back
I've try to set this value back to "Display Major Item" and all my stuff is still showing
well i still dont understand why i had this problem but after 3 week im glad that iv'e got this fixed.
Hi, I have WinCC Felxible 2008 SP5 installed on my Windows 10. I want to program Simatic panel TP177B using USB transfer cable. But i can't...
2,120
Hello! Another weird request from the swede with customers that doesn´t like to pay for quality in first place... Is there any way to have a...
2,684
Hi! I'm a little lost here. I have made a script in VB that run perfect when I simulate it on my programming machine (Windows 8.1) But when I...
2,789
Hi! Writing this in a hurry. Today we made a break at a factory and I should download new s7-1200 program and a new WinCC Flex 2008 RT program...
2,244
hi guys,,can i personalize data logging in wincc flex? i mean i want to make a table that shows log data in a better platform than in wincc,,,i...
1,426
