WinCC Flex 2008 RT Screen Resolution
idell
Nov 2009
Bucharest
97
HI!
Do somebody know how to make a project, in WinCC Flexible for PC, with another Screen Resolution (different from 1280x1024, 1600x1200 ...)?
You can change the screen resolution for PC RT only, not for panels.
You do this in the Device Settings.
Important: Before you change the resolution you must decide if you want the graphics and texts to be scaled automatically. If you choose automatically, then the endresult may not be as pretty as you might want.
The setting is under Options .. Settings .. Screen editor .. Screen options .. Fit screen and screen objects to new device.
Hi Jesper,
Have done the same as what you have advised. Mine fits the screen but the graphics are not scaled. Instead, portion of the screen is colored white. Hope you can help
You are using a screen with a different resolution than what you have configured.
You have configured a screen with 4:3 aspect ratio.
The screen that you are using seems to be a wide screen with 16:9 aspect ratio.
Thanks for the advise. Anyways, can provide guidelines with the aspect ratios? Considering the settings available on the flex, i think it will not be a good idea to use 32" LCD Monitors, or the 1080HD
The only advice I can give is to make sure that the resolution of the monitor and the resolution in WinCC Flex RT matches each other.
You can choose full HD resolution if you want to.
Hi, I have WinCC Felxible 2008 SP5 installed on my Windows 10. I want to program Simatic panel TP177B using USB transfer cable. But i can't...
2,132
Hello! Another weird request from the swede with customers that doesn´t like to pay for quality in first place... Is there any way to have a...
2,690
Hi! I'm a little lost here. I have made a script in VB that run perfect when I simulate it on my programming machine (Windows 8.1) But when I...
2,801
Hi! Writing this in a hurry. Today we made a break at a factory and I should download new s7-1200 program and a new WinCC Flex 2008 RT program...
2,249
hi guys,,can i personalize data logging in wincc flex? i mean i want to make a table that shows log data in a better platform than in wincc,,,i...
1,434
