jdf
WinCC Flex 2008 upgrade.
Hi All,
I have just upgrade WinCC 2007 Advanced to 2008 Advanced and serviced packed it with SP1, as this came with the upgrade pack. All looked good until I got home and had to dial back into site.
First off I could not connect over wireless or hard ware to my hub. It was reporting no IP address assigned. I manually put it the IP config and disabled everything I could see in task manager that belonged to Siemens then got a connection. Using WatchGuard Mobile VPN I was then able to establish a connection to site.
With a good connection showing on the VPN I was unable to connected to anything on site using DameWare or NetSupport Control.
I was wondering if anyone else had experienced similar problems and if so if they have found a fix?
Thank you in advance.
Jon
Hi All,
Jon
