WinCC Flex 2008
apolionman
Nov 2013
Dubai
47
Hello Guys! I'm wondering if you could help me how to program a modulating Interface.
By the way, I am using S7300 connected with MPI to laptop, I'm designing a SCADA system and I want to program a modulating button like potentiometer to control the 4-20mA or 0-60Hz Frequency. I'm going to control the VFD/VFI Frequency using a modulating interface in my laptop. Is it Possible?
Thanks a lot guys you really helped me alot.
Hello Thanks for the quick reply.
a SCADA object. I want to modulate the VFD using a modulating button inside the SCADA.
I don't have analog input module, I only have AO to control VFD 4-20mA. iI would be great if there's an modulating or like a scroll bar program to manually control 4-20mA.
I think in your application you will manually manipulate the speed of the VFD so no need for analog 4-20mA just insert an analog input box in the SCADA and use it's tag to change the value of the analog output you have in the plc.
I may be missing something but are you looking for something like the 'Slider' under "Too,s" -> "Enhanced Objects"?
Hi, I have WinCC Felxible 2008 SP5 installed on my Windows 10. I want to program Simatic panel TP177B using USB transfer cable. But i can't...
2,139
Hello! Another weird request from the swede with customers that doesn´t like to pay for quality in first place... Is there any way to have a...
2,696
Hi! I'm a little lost here. I have made a script in VB that run perfect when I simulate it on my programming machine (Windows 8.1) But when I...
2,811
Hi! Writing this in a hurry. Today we made a break at a factory and I should download new s7-1200 program and a new WinCC Flex 2008 RT program...
2,251
hi guys,,can i personalize data logging in wincc flex? i mean i want to make a table that shows log data in a better platform than in wincc,,,i...
1,436
